Steve F M
- Jul 17, 2003
New with 90 Day Parts and Labor Warranty. $250 shipped is the price.
The VR-7070 boasts the power and processing savvy necessary to earn Lucasfilm Ltd.'s coveted THX® Select certification. That means it's got 6.1-channel THX Surround EX™ decoding, plus THX processing enhancements like Timbre Matching™, ReEQ™ and Decorrelation™ to ensure a faithful re-creation of the movie theater experience in your home. The '7070 also boasts a full complement of surround decoding options, including Dolby® Digital EX, DTS-ES®, and Dolby Pro Logic® II.
100 full-bandwidth-rated watts x 6 channels of K-STAT™ power delivers an enveloping 360º soundfield. Kenwood's exclusive K-STAT amplifier design incorporates a thermal compensation sensor into the transistor. This not only allows instant adjustment to temperature changes, but also eliminates the usual "warm-up" period you get with conventional amplifiers. The result is improved sound quality and consistency at all times and at any volume level.
Multi-zone A/V output lets you enjoy the same audio or video source in two rooms simultaneously (requires TV, receiver, shelf system, or powered speakers in second room). The remote features an LCD for intuitive system control, plus learning capability that lets you "teach" it any function that your other remotes have. An impressive array of inputs and outputs lets you hook up all your A/V components, and a 6.1 preamp output keeps you prepared for system expansion.
Key Features:
THX Select certification
100 watts x 6 into 8 ohms (20-20,000 Hz) at 0.09% THD (surround L/R rated at 0.7% THD)
THX Surround EX, Dolby Digital EX, DTS-ES, and Pro Logic II
DTS Neo:6 modes
SRS Circle Surround II modes
32-bit processor
multi-zone A/V capability (preamp-level stereo audio and composite video output for second room)
learning/multibrand LCD remote
7.1-channel preamp output
component video switching: 2 in, 1 out (10MHz bandwidth)
digital inputs: 2 optical, 2 coaxial
optical digital output
3 audio inputs (including phono), 5 A/V inputs (including 5 S-video, 1 front-panel and one 5.1-channel)
5 audio DSP modes (Arena, Theater, Jazz Club, Stadium, Disco)
2-stage Midnight Theater mode
96kHz/24-bit D/A and A/D converters
banana plug-compatible binding posts for all main-room speakers
2 sets of main speaker outputs
anti-resonant aluminum front panel
40 AM/FM presets
17-5/16"W x 6-5/16"H x 16"D
Key Features:
DTS Neo:6 modes
32-bit processor
40 AM/FM presets
