FS: Donner Haus DH-10 Subwoofer (1 Viewer)
JarrettJ
This is a great little 10" (front firing) powered subwoofer with 150 watts RMS (400 watts peak).
Sub is in great shape (9/10 conservative) and has been used for about a year. Never driven hard and sounds great for movies or music. Doesn't go real low but still adds a nice punch.
A few specs:
Amp Type: High Efficiency, high output Class "D" amp
Amp Features: High Dynamic Power Design, LFE input, Phase switch, crossover control, driver compensated EQ circuitry and automatic turn on/off
Low Pass Crossover: Precision Variable Electronic Crossover 50-150 Hz
Rated Power: 400 watt peak
Max Input (high level): 150 watt/channel @ 8 ohm
Inputs: both low level (rca) and high level (binding posts)
Sub is the standard black box with dimensions 42.5h x 31.6w x 41.5d (cm). Weight is 36.7 lbs.
I have the original box and manual.
Prefer local pick up (near Niagara Falls, Ontario) but will ship if buyer wishes.
Email with any questions.
First $210 takes it. Great sub for the value.
Jarrett
[email protected]
eathree
