FS: DLP front PJs (1 Viewer)
ThuanVu
Hi all,
I have 2 DLP PJs forsale:
The Plus UP1100 was one of the good HT PJ two years ago, you can search info at www.avsforum.com
It has less than 100hrs usage (i think) - PQ is awesome with HD source
Specs at http://www.projectorcentral.com/PLUS-UP-1100.htm
Price $650
The NEC LT260K is current model - very bright (2400 lumens) - awesome PJ
It has less than 200hrs usage (have to check on it)
Specs at http://www.projectorcentral.com/NEC-LT260K.htm
Price $1750
I can swap the new lamp if you want for $1800
Thuan
andriesprice
