James Sybert
- Jan 25, 1999
Link Removed
i have the unit, the owner's manual and the remote to sell.
here are the specs:
Here are the specs: Rated output Front 85 W + 85W(8 ohms, 20 Hz - 20kHz with 0.05% THD) Center 85W(8 ohms, 20 Hz - 20kHz with 0.05% THD) Rear 25 W + 25 W(8 ohms,1 kHz with 0.1% THD) Dynamic Power (Front) 115 W + 115 W (8 ohms)170 W + 170W (4 ohms)225 W + 225W (2 ohms) Preamplifier Section Input sensitivity/Impedance PHONO (MM) : 2.5 mV/ 47 kohmsCD, DAT/TAPE, VDP/TV, VCR-1, VCR-2V-AUX : 150mV/ 47 kohms Output level/Loadimpedance FRONT(L,R), MONO, CENTER :1.0 V/ 10 kohmsDAT/ TAPE,VCR-1, VCR-2MULTI SOURCE : 150mv/ 47 kohms Frequency response 10 Hz - 50 kHz + 3 dB RIAA deviation 20 Hz - 20 kHz + 1 dB Signal-to-noise ratio(A-weighting) 92 dB (STEREO) Tone control Treble : + 10 dB at 10 kHzBass : + 10 dB at 100 Hz Video Section Input terminal VDP, TV, VCR-1, VCR-2, V.AUX/GAME:1 Vp-p / 75 ohms Input terminalS-Video :VDP/ TV, VCR-1, VCR-2, V.AUX /GAME Output Terminal VCR-1, VCR-2, MONITORMULTISOURCE: 1Vp-p/ 75ohms Output terminalS-Video VDP/ TV, VCR-1, VCR-2, Signal-to-noise ratio(A-weighting) Mono : 80 dB, Stereo : 75 dB Total harmonicdistortion Mono : 0.15%, Stereo : 0.3% AM Section Tuning frequencyrange 520 - 1710 kHz Usable sensitivity 18 µV Signal-to-noise ratio 50 dB General Power supply AC 120 V, 60 Hz, Power consumption 5.0 A Dimensions 434(W) x 161(H) x 436(D)mm17.1"(W) x 6.3"(H) x 17.3"(D) Weight 11.7 kg, 25.0 lbs.
Has RDS. Is Dolby® Pro-Logic · Has 9 surround modes · Supports on-screen displays · Has Dynamic Discreet Surround Circuitry (DDSC) · Has Subwoofer out
There are S-Video connections for all four video inputs.
here are some reviews on it:
http://www.audioreview.com/A-V,Recei...1_2718crx.aspx
http://www.sonic.net/soundscape/pdenon.html
i'm asking $199.00 plus true shipping costs (ground ups).
let me know if you're interested. [email protected]
here are the specs:
