Chris
- Jul 4, 1997
Dazzle DVC-II Video capture device, it's a MPEG-2 encoding PCI card & an external breakout box. Includes media capturing software (four discs worth). Works very well to capture VCD or DVD quality, check out details at: Link Removed
Brief stats:
Specifications-Video
Video Format: MPEG-2, MPEG-1, RealVideo, MPEG-4/ASF
Capture Resolution:
720 x 480, 352 x 240, 320 x 240, 176 x 120, 160 x 120 NTSC
720 x 576, 352 x 288, 176 x 144 PAL
Frame Rate: 30 fps-NTSC, 25 fps-PAL
Controls: Sharpness, Tint, Brightness, Contrast, Saturation
Video Bitrate: 2 to 10 Mb/sec
Inputs: Composite and S-Video: NTSC, PAL
Outputs: Composite and S-Video: NTSC, PAL
Playback Resolution
TV: Full screen (NTSC and PAL)
Computer: Up to full screen
Specifications-Audio
Audio Format: MPEG and WAVE
Bitrate: 64Kb/sec to 384Kb/sec
Sampling Frequency: 32KHz, 41.1KHz and 48KHz
Modes: Mono, Stereo
Input/Output: Dual RCA jacks
MIC Input: Mini mono jack
Controls: Volume and input gain
Specifications-Still Image
Resolution: Up to 1600 x 1200 pixels
File Formats: BMP, JPG, TIF, PCX, TGA, WMF, EPS, FPX, PSD
Modes: Single, multiple, and periodic snapshots
System Requirements
CPU: 400MHz or higher Intel Pentium II/Intel Celeron/AMD K6-2
OS: Windows 98®, Windows 2000® Windows Me® or Windows XP®
RAM: 64MB minimum
Disk Space: 60MB-Dazzle Software / 200MB-Bundled MPEG video 25MB-All bundled software / 0.5-15MB per minute rec. video
Graphics: 800 x 600, DirectDraw compatible graphics card
Sound: PC must have a sound card
Interface: PCI
Seeking $140
Brief stats:
Capture Resolution:
Playback Resolution
Modes: Mono, Stereo
System Requirements
RAM: 64MB minimum
Interface: PCI
Seeking $140
