FS: Boston Acoustics Bravos (black)
Tom Donaghue
I've been struggling with letting these go, but they're just too much for my bedroom. These are in almost new shape, used as surrounds in my main theater setup for a short time, but have been in storage for the past 6 months or so.
These will come with the original corner, horizontal and wall mounting brackets as well as the original packaging from OneCall when I bought them. Matched up with a decent subwoofer, these make for an excellent alternative to full size mains that provide a great soundstage regardless of their size. As they can be vertically as well as horizontally mounted, they're pretty flexible, too. As a lot of tools incorrectly list their specs on eBay, here they are direct from BA:
Frequency Response: (±3dB) 80–20,000Hz
Recommended Amplifier Power: 15–125 watts
Nominal Impedance: 8 ohms
Sensitivity: [1 watt (2.83v) at 1m] 89dB
Bass Unit: 4 1⁄2" (115mm) copolymer
Tweeter: 1" (25mm) VR black anodized aluminum dome with AMD
Crossover Frequency: 2500Hz
Dimensions with corner fillers (HxWxD): 14 1⁄4 x 6 1⁄2 x 5 1⁄4" (362 x 166 x 134mm)
Dimensions w/out corner fillers (HxWxD): 14 1⁄4 x 6 1⁄2 x 4 1⁄4" (362 x 166 x 108mm)
Weight: 5 lbs (2.25kg)
Finish: White or black textured ABS with matching cloth grille
These were over $300 new, my asking price is $225 or best offer shipped. Here's a snapshot of one previously set up in my system. Any questions, please let me know... -TD
Tom Donaghue
Hi Jeff;
Unfortunately I'm looking to trim things down a bit. Thanks for the offer all the same... -TD
conradfan
