Dan Marchewka
- Sep 17, 2001
This amp is in like-new condition. I will ship it in it's original double box. I am asking $925 shipped via UPS insured. Money order or cashier's check preferred, paypal accepted. My email address is: [email protected] You can also look at my ebay feedback rating--marchewd.
Below are the Details:
Five-Channel Power Amp This exceptional amplifier is truly the addition your audio system needs. Fully hand crafted in America, this component uses only high quality parts. In fact, this amp uses the same type of components that medical and military equipment specify.
Specifications: Five Channels 200 Watts into 8 ohms & 350 Watts into 4 ohms 20Hz to 20kHz Frequency Response ab Power Class 110 db SN Ratio 0.06 Percent THD Input Sensitivity - 1.1 volts for full output Input Impedance - 20K ohms 47 lbs 17" x 14" x 6 3/4" Engineered for Both Music & Movies Acurus amplifiers are engineered with the understanding that they will need to be exceptional with two-channel music reproduction as well as with home theater. Acurus amplifiers are therefore a solid choice whether you're going to be listening to audio, watching movies in your home theater or doing both! Flexibility is a good thing; in fact in the audio world it's a great thing. So, having an amp that performs well any way you use it is the way to go. This five-channel amp has separate two channel and three channel sections. The stereo section even has additional heat sink cooling to provide over 150 watts per channel of continuous power for the two main front speakers. Symmetrical Channel Configuration Acurus has evolved their theories of audio excellence into high-end amplifiers of exceptional smoothness. This smoothness was not achieved at the expense of detail however. The ability to retrieve detail found within the original source has actually been improved. Acurus' new symmetrical channel configuration reduces harshness and inter-channel anomalies allowing for the increased smoothness and detail. Real Glass Epoxy Circuit Boards Unlike many other amplifiers in the Acurus price range, all Acurus amplifiers employ glass epoxy circuit boards. Is glass epoxy really superior to the paper circuit boards found in many other manufacturer's product? Absolutely; that's why all medical and military equipment specifies glass epoxy.
Dan
Dan
