FS: 850 mhz Slot-A T-bird with dual-fan HS..
Discussion in 'Archived Threads 2001-2004' started by Chris PC, Sep 11, 2002.
  1. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    I bought a few brand new T-bird Slot-A's in the hope of upgrading mine and my fathers PC and now plans have changed. I upgraded mine but he is not keen on upgrading. The CPU is great and overclocks well. I ran 112 mhz Front Side Bus to obtain 950 mhz. I only used in my Asus K7M for a month with 106 mhz FSB though [​IMG]
    Here are the motherboards it works with.
    Asus K7M and K7V-t
    NOTE:"Asus K7V-t. That "-t" is very important. Check AMD website for full motherboard compatibility as listed here:"
    FIC
    SD-11
    Freetech
    P7F200
    Gigabyte
    GA-7IXE
    Microstar
    MS-6195
    Shuttle
    AI61
    Soyo
    K7AIA
    $60.00 USD plus shipping. This is a good upgrade if you have a slower Slot-A and want more speed by simply swapping the CPU. Comes with dual-fan CPU cooler (sounds cheesy but it works as good or better than my Golden Orb for Slot-A). With golden fingers you might be able to overclock more.
  2. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Make me an offer [​IMG]
  3. Jerry Klawiter
    Jerry Klawiter Screenwriter
    Dec 3, 2000
    1,412
    You have a PM
  4. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Jerry,
    I PM'd you. You have an INTEL MB and mine is an AMD CPU and they do not work together.
    JonathanF,
    Whether you can use my 850 mhz T-bird depends on what chipset your motherboard is. What is your motherboard and what is the chipset? I started with an Athlon 550 mhz! Aren't we just the early adopters [​IMG]
  5. Paul Clarke
    Paul Clarke Supporting Actor
    Jan 29, 2002
    998
    Chris,
    Sent you a PM.
  6. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Paul and jonathan,
    Jonathan are you interested? If not then Paul is next in line [​IMG]
  7. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Jonathan? Anybody else? This is a good cheap upgrade.
  8. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Price drop $60.00 USD plus shipping.
