Matthew Anderson
I have read somewhere before about a formula for how far apart your front speakers should be in relation to the distance from listening position. Thanks for any thoughts.
I was told that fronts 8 ft. apart mean a 9' 7in seating distance.
I seriously doubt you can come up with numbers accurate down to the inch which are optimal for any combination of room and speaker. I agree with the previous posts - 60 degrees or maybe a little less, and the key point is to experiment, because every room/speaker combination will have a different optimal location.
With that in mind, if someone can tell us how to properly determine how far 60* is, please translate that into an approximate distance.
Well, 60 degrees makes an equilateral triangle, and an equilateral triangle is simply one in which all 3 sides are of equal length. So, an easy way to check this is, if the distance between your speakers is 8 feet, then the distance from the listening position to each speaker should also be 8 feet. Note, not the distance from the listening position to the line joining the speakers, but the distance measured directly from the seat to the speaker.
If you want to be accurate, I believe the distance from the seat to the line joining the speakers should be equal to:
(distance between speakers) * SquareRoot(3) / 2
Which, using the calculator on my computer, comes to:
(distance between speakers) * 0.866
For 8 feet, that comes to 6.9282 feet or 6 feet and 11.13 inches
(it's easy to give numbers down to 4 places of decimals when you have a calculator open in front of you )
For more HT Speaker placement, INFO, see http://www.dolby.com/ht/Guide.HomeTheater.0110.html My HT Enthusiasts Website3. Speaker placement said:Quote:
