Craig John
- Jun 18, 2003
I'm seriously considering a FP, possibly the NEC HT1000 or the Sony VLP HS10. While I don't have any experience with FP's, I have been into HT for a LONG time! My current TV is a 1987 Pioneer SP 501, one of the "original" 50" RP TV's, (that still looks spectacular, I might add).
If I want to watch a Sunday afternoon football game on the FP, how much light do I need to block out of the room? I have "room darkening" blinds on the door and windows, but they don't make the room completely black. Also, I have friends over to watch the game regularly and it would be a little wierd to sit in a totally dark room with a bunch of guys watching a football game. You would hardly be able to find your beer. Anyway, what is the maximum amount of light a FP will tolerate?
If the projector is located behind your seating position, do you need to aim the remote control backwards to change inputs? (That would be awkward).
Since a FP mounts relatively distant from the source components, it will require some cabling. I have several cabling questions:
DVI Inputs. What is the longest length a DVI cable can be? Also, how does one switch DVI sources, such as an HD DirectTV receiver and a DVI enabled DVD player.
Component Video Inputs. What is the longest length a component video cable can be? Are there any interference problems with lights or electrical cables?
RGB Inputs. What is the longest length an RGB cable can be? For you guys with computers hooked to your Fp's, can the computer signal be "boxed" in a PIP window? Can you mix different signal types in the PIP window, i.e., DTV and computer, etc.
Are there any other installation concerns I should know about?
MY room is an LEDE room that will need some significant modifications to incorporate the FP and screen. I'm thinking about a 106" Draper Clarion Screen using HiDef Grey material. My seating distance will be about 14' from the screen and the projector will be ceiling mounted about 12' from the screen. My Klipsch HT speakers will be on stands on either side of the screen with the center channel mounted below it. Is there any problem having the speakers positioned somewhat "in front" of the screen? My speakers have a rear passive radiator and can't be placed on the wall. Would I be better off mounting the screen out from the wall far enough to let the speakers be in the same "plane" as the screen?
Sorry for all the questions, but I really appreciate the help. If I'm going to do this, I want to do it write, (oops, right).
Thanks!
Craig
Thanks!
Craig
