Front Projection Screen Option Shock (1 Viewer)
Bill_Br
Bill Browning
Wow, how to decide which projection screen to buy for a home-theater system? For example, below are just three of many options on eBay, ranging from about $25 to $100:
"Acoustically transparent screen has a gain of 1.0 and is bright white for a large viewing angle.
"The most versatile screen surface and the premier choice when ambient light is controllable. It evenly distributes light over a wide viewing area while colors remain bright and life-like, with no shifts in hue. Gain 1.0 Viewing Angle 50°
"A brand new never used piece of rubberized matte white canvas screen material. Gain of 1.3."
Is there a thread on this forum or someplace elsewhere on the web where a newbie like myself can learn about the dos and don'ts of buying front-projection screens? Or any suggestions that anyone would like to make here.
Thanks!
Bill
Chad Isaacs
check out the screens area over at avsforum, you will find more info than you know what to do with from screens that cost $10 all the way up to $10,000
gyao
