Front projectiion geometry
Discussion in 'Beginners, General Questions' started by hargrave, Feb 24, 2004.
  1. hargrave
    hargrave Auditioning
    Dec 31, 2003
    6
    Is there a site that will elaborate on the geometry of projector throw? Is there maximum and minimum? Are they all the same? Is there an optimum? If I buy a screen first, am I limited with future projector options? Where do I go from here?
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,185
    51
    9,110
    Katy, TX
    Wayne
    Hargrave,
    You’ll have better luck if you post your question on our “Display Devices” Forum.
    Wayne A. Pflughaupt
  3. ChrisTheg
    ChrisTheg Agent
    Mar 1, 2003
    28
    Almost every projector is a little different so I would pick the projector first then go from there. I dont think I would consider getting the screen first although it wouldn't handicap you.
