Chris PC
- May 12, 2001
Here's a very simple question about Home Theatre speaker placement. I assume that the ideal placement for front speakers, regardless of bass response (using a sub), in terms of sound directionality, is to place the Left and Right front speakers so that the tweeters are about half way up the TV. If you drew a line between the tweeters, they would cut the tv screen in half vertically. Is this sensible placement? Is a bit higher better? I will have a center channel above the TV.
Front setup will be PSB 4T's and 8C center (speakers have identical drivers)
[Edited last by Chris PC on July 15, 2001 at 08:02 PM]
