front l/r distance compared to rear surrounds
Discussion in 'Archived Threads 2001-2004' started by MichaelDW, Mar 24, 2002.
  1. MichaelDW
    MichaelDW Stunt Coordinator
    Dec 2, 2001
    60
    when setting up a surround system if your L/R front speakers are restricted to say 4' apart. would you want your rear surrounds same distance apart or further apart if possible? my room is 15'/20' I have the option of putting my surrounds 20' apart to the sides or directly 3'behind me 6' apart trying to decide what the best option is and dont have the luxury of moveing the speakers around being they are inwall and cant go around cutting holes everywhere. thanks for replies
  2. Harry Lincoln
    Harry Lincoln Stunt Coordinator
    Sep 29, 2000
    193
    Personally, I'd go with the side placement.
    Harry.
  3. Brad Craig
    Brad Craig Stunt Coordinator
    Feb 1, 2002
    58
    Goto www.dolbydigital.com and then click on home theater on the left column for ideas on surround placement for the rears...
    Side placement would be best but they do illustration for rear wall mounting and different ways of trying them out for maximum effectiveness >>> though in your case you are doing in-wall thus eliminating alot of what you can do...
  4. MichaelDW
    Dec 2, 2001
    60
    thanks for your help I was thinking of getting a sunfire architectual sub would it be enough to fill that size room if its an open concept? thanks again
