Front Effects Speakers
Discussion in 'Archived Threads 2001-2004' started by Gruson, Aug 20, 2002.
  1. Gruson
    Gruson Second Unit
    Sep 20, 2000
    494
    I am very curious about these. My receiver does not support them, at least I do not think it does (Yamaha RX-v1000).
    I hear you are supposed to space these further apart and higher up than main front L & R speakers.
    Do they really add that much? I have a 7.1 set up now and I guess adding these would take me to a 9.1 system.
    Please post your reviews using front effects speakers.
    Thanks all...I may just have to upgrade my receiver now.
  2. Gruson
    Gruson Second Unit
    Sep 20, 2000
    494
    No one is using the front effects channel?!?!?!
    Please post because I want to know if it is really worth the $$$$.
    Thank you.
  3. Sheldon C
    Sheldon C Second Unit
    Dec 27, 2001
    379
    I have the rxv 3000 and I do use the front effect channels. My experience is that they work better out to the sides towards the front of the room for best results. You have to have a pretty wide room for them to really work well. I've gotta go, I'll post more later if you need it.
  4. ken thompson
    ken thompson Second Unit
    Jun 5, 2000
    251
    I use them and like them on my 2095. You will not really have a 9.1 system since the effects channels are simply main speaker data set at delay
  5. Scott Falkler
    Scott Falkler Second Unit
    Oct 23, 2001
    442
    I use the 2095 as well, and use some smaller speakers for the front effects, but I wouldn't buy another reciever to get them.
