1. The HTF Tapatalk application has been discontinued. Please see the thread in the Forum Help & Feedback area for more information.
Fp screen
Discussion in 'Archived Threads 2001-2004' started by Chad Isaacs, Jul 25, 2001.
  1. Chad Isaacs
    Chad Isaacs Supporting Actor
    Feb 20, 2000
    757
    Well,I am slowly but surley saving for a fp system.To start I think I will try out a diy screen.
    What my concern is is kids...I have 2 and they have crayons.So what I was thinking is..Make the screen around a wood frame.Then attach the frame to the celing using some sort of chain or hinge,when the screen is not in use pull it up flush to the celing and put some sort of hasp so it will stay in place.
    Is there anything wrong with doing this?My concern is dust.If the front of a screen wether it be pro or diy what is a good method of cleaning it?
    I am thinking of either making it from canvass or black out material.
  2. John-D
    John-D Stunt Coordinator
    Feb 27, 2001
    198
    Chad if u're planning for a 'lamp' projector then it might not be an issue.. but anything on the lines of those finicky CRT's and there might be issues.. UNLESS you are always able to lower the screen down EXACTLY where it was.
    Blackout works great and cleans well with anything u'd clean a blackout fabric with.. soft clean cloth should be good for the vinyl side at least.
    Another option would be to by a large plastic sheet and find someway of fixing it so it just rolls up and drops over the screen when not in use.
    Good Luck
    The things we own end up owning us
  3. Chad Isaacs
    Feb 20, 2000
    757
    I am looking to get a lcd fp...be nice to get ahold of a used sony vpl400 or somthing simmilar.
  4. John-D
    Feb 27, 2001
    198
    are you even considering other PJ's?
    what's the total budget?
