fp screen
Discussion in 'Displays' started by Michael_-==+, Oct 11, 2003.
  1. Michael_-==+
    Michael_-==+ Auditioning
    Oct 9, 2003
    3
    Hello this is my first post to HT forum. I've been reading for a couple of weeks. My question is has anyone built their own screen for front projection. I was planing on building my own and I wanted to try to get some ideas. So far I've only seen screen material on ebay.I dont know if this stuff is any good. Does anyone have any experience with it good or bad. It seems silly to me to buy a screen when I have access to professional framing equipment and moulding and such. Any ideas tips would be much appreciated. Oh by the way I plan on going with a 90" 4:3 screen if that helps. Gonna use an X1.
  2. Legairre
    Legairre Supporting Actor
    Apr 4, 2000
    815
    I sent you a PM that might help
  3. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
  4. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    The blackout fabric stretched over the frame is the most common idea that I have seen. If you have a section left over you may try experimenting with various colours to paint onto the screen for the X1 that supposedly reduce rainbows.
  5. Bryan Michael
    Bryan Michael Supporting Actor
    Mar 2, 2002
    564
    lets say i wanted to go 120 diag in a 16x9 can i diy this or should i just get a good screen. also if i buy a screen should i get a entry level and upgrade or shell out for a realey great screeen? and what is the lifespan of a screen?
  6. Kevin Deacon
    Kevin Deacon Second Unit
    Dec 18, 2001
    319
    Go to the avsforum.com. There is mucho info about diy screens and pj's.
