Garrett Lundy
- Mar 5, 2002
I'm going to convert a bedroom into my new HT. The room is 12' by 13' and has no windows or other sources of unwanted light.
I'm looking for a FP with EDTV capabilites because it will be used for DVD watching only (16:9 if possible). I'll buy a full HD projector in a few years when prices go down and PQ goes up.
Feel free to suggest older models that I might be able to find that would give a good bang for the buck. CRT, DLP, LCD its all good. Cost: lets keep it under $1000.
Requirements:
*Must be quiet enough to run in the room. Its a rented apartment so no cutting holes in a wall.
*Component video inputs would be great. I could purchase a DVI-equipped DVD player if I need to.
Thanks in advance!
Requirements:
Thanks in advance!
