Found some good sub drivers
Discussion in 'Home Theater Projects' started by Mike SJ, Mar 30, 2004.
  1. Mike SJ
    Mike SJ Supporting Actor
    Nov 10, 2003
    718
    2 of these in a 4 cu ft box
    Characteristic sensitivity (2.83V / 1m) : 83 dB
    Recommended frequency range : 21 - 500 Hz
    Free air resonance frequency, fs : 20.5 Hz
    DC resistance, Re : 3.4 ohm
    Voice coil inductance, Le : 0.47 mH
    Effective piston area, Sd : 232 cm²
    Moving mass incl. air, md : 106 g
    Mechanical loss, Rm : 2.9 Ns/m
    Force factor, BL : 9.7 Tm
    Equivalent volume, Vas : 43.5 ltr.
    Mechanical Q-factor, Qms : 4.7
    Electrical Q-factor, Qes : 0.49
    Total Q-factor, Qts : 0.44
    Excursion, lin./max. : ±13 / ±20 mm
    Voice coil diameter : 50 mm
    Rated power handling : 225 W
    Net weight : 4.6 kg
  2. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    Mike,
    Which company made the drivers? @ 83dB, they don't seem very efficient, though.
  3. Mike SJ
    Nov 10, 2003
    718
    SCAN SPEAK
  4. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    SS 23-4557T00
    [​IMG]
    Since they'll probably retail for ~$800+/pr, I can think of quite a few other drivers I'd rather have........
  5. Mike SJ
    Nov 10, 2003
    718
    well I m thinking those are as close as ill come to finding a match to the martin logan woofers
  6. Dan Hine
    Dan Hine Screenwriter
    Oct 3, 2000
    1,312
    Why do you think that? It's been awhile since I listened to some Martin Logans.
  7. Mike SJ
    Nov 10, 2003
    718
    Ive been reading up at a web site for ML's and I know the drivers are scan speak's and those are closest to what I got. basket is a bit different and dust cap is different. but as i said, its the closest ive come to finding t/s params for what I have
  8. ThomasW
    Nov 6, 1999
    2,282
    Althought I find it hard to believe that ML actually uses SS drivers, the reality is that you don't need SS drivers to match up with ESLs.
    If you're after a the 'best' sub, then look long and hard at either dipole or IB configurations. I have both Maggies and ESLs and IB or dipoles are the only types of subs that 'match' the sound quality of planars....
  9. Kyle Richardson
    Kyle Richardson Screenwriter
    Jan 1, 1998
    1,073
    They might be a nice sounding driver but they may be quite difficult to make work well. With the very low sensitivity combined with the fairly low power handling of 225W and the fact that it doesnt take much power to send these past xmax in the enclosure you stated you will be hard pressed to get much output out of them.
    Again, I dont have any experience with these first hand but those are my thoughts when looking at the parameters.
  10. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Also, keep in mind that a 4 ohm driver with a sensntivity of 83dB at 2.83V/1M will only be 80dB at 1W/1M.
  11. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    thats horrible
  12. Mike SJ
    Nov 10, 2003
    718
    well i guess ill have to keep searching
  13. ThomasW
    Nov 6, 1999
    2,282
    For what?
    It's going take more than buying a extremely expensive driver to keep 'pace' with planar speakers.
    You must consider the transient response of the design of the sub itself. So consider an IB sub if circumstances permit. If not, take a long hard look at dipole subs, their bass is EXTREMELY high quality...
  14. Mike SJ
    Nov 10, 2003
    718
    Im not "trying" to reproduce anything. Im probably not explaining myself well.
    besides IB subs, are you saying that the dipole subs are the next step down? My sub is sealed. but its not a finished box, just a temporary solution. basically I have scrap 1" MDF with walnut veneer on one side at my disposal. The pieces are large enough to make a nice sub box and then the fronst for my new bookshelves. I am trying to make susre I dont waste the walnut or the woofers or my money. I appreciate all the input I can get.
  15. ThomasW
    Nov 6, 1999
    2,282
    I'm saying that IB or dipole make the best bass, much, much better than sealed.
    I've experimented but at this point I'm not sure which is better IB vs dipole. They are virtually identical. One does need multiple drivers for either alignment.
    I'm currently playing around with a all dipole, fullrange system that started with a pair of 12"s/side. The bass was very good but lacked 'punch'. Now with 4-12"s/side it's almost a dead heat vs my 4-12" IB sub in the lowest octaves
    [​IMG]
    BTW note that I also have Maggies and Acoustat 1+1's, so I have a good basis for comparison..
  16. Mike SJ
    Nov 10, 2003
    718
    dang, maybe I should send you one of my drivers to play with for a while...
    hmm . just to make sure I know what dipole is, it is both speakers moving in the same direction? not both in like an isobaric though. right?
  17. ThomasW
    Nov 6, 1999
    2,282
  18. Mike SJ
    Nov 10, 2003
    718
    hey Thomas, are those Dynaudio woofers?
  19. ThomasW
    Nov 6, 1999
    2,282
  20. Geoff L
    Geoff L Screenwriter
    Dec 9, 2000
    1,693
    Hi Mike
    Dipole subs are not the eaisest things to design and build, let alone the cost involved usually to get nice room pressurization. Multi drivers are generally the rule, and per side at that.
    The IB is much easier to build/construct and unless your looking for a major challange the dipole would not be my first choice if you have the room to do an IB.
    I'm not sure, others may know, but dosen't PE have driver measureing equipment....? For a fee you could send them one a least and get you true TS params for these mysterious ML 10's drivers.???
    Thomas:
    Boy those sure are good size speaks, you using a dolly to move them around..[​IMG]
    Which series HI VI Research drivers are you using in the pic you posted? (I belive thats what your using), if so what do you think of them. I ran the M8A which PE dropped, probley due to cost and really like them ALLOT. Have not heard the MN or F series in anything nice yet.
    Can't see the tweet clear enough to even take a guess. So what you hiding their?
    ELS's, & Maggies, tuff job to smoke out some killer deep fast bass for those speaks. ~{Fast bass is a kinda play on words here}~....!!! [​IMG]
    You know what I mean, more of a running joke with the un-informed bass crowd.
    You have any old Quads laying around also, you seem to never cess to amaze me with all the stuff that shows up at your links/site..
    Regards
    Geoff
