Fosgate Audionics FA12.0 Subwoofer
Discussion in 'Archived Threads 2001-2004' started by Marvin E, Sep 14, 2002.
  1. Marvin E
    Marvin E Stunt Coordinator
    Mar 1, 2001
    90
    Does anyone have any experience with the Fosgate Audionics FA12.0 12" Powered 200 watt Trans•ana Class-G Subwoofer?
    I couldn't find any reviews. From what I can tell, it must be a new model:
    • 200 watt/channel patented trans•ana Class-G power amplifier
    • Slot ported enclosure for extended low frequencies
    • Adjustable 24dB/octave Linkwitz-Riley crossover from 40Hz -110Hz
    • 90/180/270 degree phase switches
    • RAD manufactured, cement coated cone, proprietary driver
    Performance Specifications:
    System Type 6th Order Vented
    Frequency Response 25Hz-100Hz, +/-2dB
    Peak Acoustic Output
    (w/music @ 2m) >115dB
    Total Harmonic Distortion 100dB
    Slew Rate - specification not applicable -
    CMRR >70dB typical @ 60Hz
    Input Impedance 47k ohms per phase balanced, 47k ohms unbalanced
    Sensitivity Range RCA Input: 160mV to 5V RMS
    Normal Operation: 66W / 380mA @ 230VAC
    Full Power: 330W / 3.3A @ 120VAC
    Full Power: 315W / 1.7mA @ 230VAC
    Crossover Specifications:
    Crossover Slope 4th Order Linkwitz-Riley (24dB/octave)
    Crossover Frequency Variable from 40Hz-140Hz
    Bass Shelving - specification not applicable -
    Subsonic Filter 12dB/octave (-3dB @ 18Hz)
  2. Wes
    Wes Screenwriter
    Sep 30, 1997
    1,190
    Utah USA
    Wes Peterson
    I have not heard of it but if I remember correctly Jim Fosgate sold Fosgate Audionics to Rockford Fosgate back a couple years ago. So you would be getting Rockfords years of amp and speaker technology!
    I don't think you could go wrong!
    Wes
  3. Marvin E
    Mar 1, 2001
    90
