Formatting for dummies - software available?
Discussion in 'Computers' started by Ronald Epstein, Mar 5, 2004.
  1. Ronald Epstein
    Ronald Epstein Founder
    48,304
    5,479
    9,110
    What is the easiest way for one to
    completely format the hard drive of
    a computer that is about to be thrown out?
    I need to know specifically if it can be
    done through Windows 98 software or through
    the installation of a separate piece of software.
    My friend thanks all of you for the help.
  2. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Do you want to make sure no one ever gets access to any old data or is a simple format ok?
    If you just want to remove everything just enter DOS and type format c:
  3. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    110
    If you have a good drill and metal bit just drill all the way through the case in a coupla spots.
    Works great.
    I also understand that you can still retreive info from a formatted HD.
    Brent
  4. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    Look for PartitionMagic (not free). It is a wonderful partitioning program and has a secure erase function. Also, if don't ever want to use it, you could just take it out and put a large magnet on top of it for awhile.
  5. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    If it's a Maxtor or Western Digital hard drive, you can go to their website and download MaxBlast tools or WD Diagnostics, which will allow you to create a boot disk that will allow you to low level format the hard drive in question (writing all zeroes to the drive is the same thing as a low level format).
  6. StephenL
    StephenL Second Unit
    Nov 21, 2000
    341
  7. Christian Behrens
    Christian Behrens Supporting Actor
    Mar 2, 2000
    714
    110
    SF Bay Area
    Christian Behrens
    I second the low level format. But if you only need to remove a couple of personal data files, this will be enough in 99.99% of cases:
    http://www.heidi.ie/eraser
    Yes, it's free!
    -Christian
