format quality evaluation
Discussion in 'Archived Threads 2001-2004' started by Mike Kennedy, Feb 2, 2001.
  1. Mike Kennedy
    Mike Kennedy Auditioning
    Dec 5, 2000
    9
    Having just finished upgrading just about everything, I decided to do a personal evaluation on all my different formats. I will get tired of playing with all this stuff one of these days, but not just yet.
    My evaluation (from 0 to 10)
    Dish demo; HDTV specials (super bowl, golf): 10
    Other HDTV (networks, dish movies): 7-9
    DVD's 6-8
    Laser discs 5-6
    c-band satellite 4-6
    OTA broadcasts 4-5
    Dish standard def satellite 2-4
    static 0
    Surprises:
    - the quality range on HDTV
    - the high quality of dvd's on HDTV sets
    - c-band quality over dish network
    - upconverts--YUUCK
    Is this consistent with other's views?
    Mike
  2. Judy Y
    Judy Y Stunt Coordinator
    Feb 27, 2000
    119
    I would say you have broken it down quite nicely- but I don't know a thing about c-band!
  3. John Perun
    John Perun Auditioning
    Oct 23, 2000
    3
    Good evaluation, I would put C band in the same catagory as Laser Discs.
    Learn & Live
  4. Frank
    Frank Stunt Coordinator
    Aug 4, 1997
    162
  5. Wayne Bundrick
    Wayne Bundrick Cinematographer
    May 17, 1999
    2,358
    I agree, C-band can look very nice, when it isn't suffering from the black sparklies. I've noticed that not even the DBS companies with huge dishes at their uplink sites can get rid of the sparklies on some of the channels. At its best, C-band is somewhere between laserdisc and DVD.
    However, I would rank OTA NTSC broadcast below DBS. NTSC broadcast has no more than 336 lines of horizontal resolution, plus it suffers from noise and ghosting. DBS is capable of more resolution and its mode of transmission doesn't cause noise or ghosts, instead there are MPEG artifacts. The local channels on DBS are heavily compressed and they are much worse than both the broadcast signals and the other channels on DBS, but generally DBS looks better than broadcast.
  6. Mike Kennedy
    Dec 5, 2000
    9
    Frank,
    You have a point that the best HDTV is significantly better than the best dvd, but on my system, not 5 times better. On a linear scale, I would probably change my hdtv rating to 7-20. However, some of my dvd's in my opinion have been at least equal to some of the hd stuff I have seen.
    Mike
