Forgive possible repeat - TosLink vs. Digital coax (1 Viewer)
Mike Romo
Mike Romo
Forgive me if this has already been discussed.
So, years ago, I went with an optical cable from bettercables.com and figured that this was the way to go. Just the other day, as I was buying my component video cables from them, I saw this on their website:
What is better OPTICAL or DIGITAL COAX?
Generally speaking, when you have the choice between toslink (optical) and digital coax, the digital coax sounds better. Both carry a digital signal, but the optical signal goes through 2 extra conversions (electrical->light and light->electrical). The optical connection has shown to have more jitter problems.
Do you guys agree with this? Why did "they" include optical in the first place? I would think the signal would be more clear...
thanks!
mike
matt-f
I personally prefer coax myself. I pretty much use it for all my connections unless there is a device that only has optical output only.
Leo Kerr
I use some Toslink and some coax - again, some devices only support one or the other.
My preference is from an economic standpoint: a decent 75ohm cable is much cheaper than the cheapest crap Toslink cable.
As for sound, well, in a well designed and built piece of hardware, there shouldn't be any difference. (Is that safe enough because of the qualifiers?)
Leo Kerr
Mindy
