Focal - Center Channel Problem
Discussion in 'Home Theater Projects' started by Tom-K, Dec 4, 2003.
  1. Tom-K
    Tom-K Stunt Coordinator
    Nov 29, 2000
    119
    I'm in the process of building/helping a friend build the focal Super center channel kit from Zalytron to match some Aria 7 mains and am having some problems with the midrange section of the center channel. When playing the center channel thru a Carver 705x, the center channel seems to be clipping. We have tried each section separately, and the woofer circuit and the tweeter circuit work fine. However when testing the midrange alone, the amp clips continuously. Has anyone else had any problems like this? I would think a stand alone amp would have no problem driving a load represented by this driver. Any ideas?
  2. Mike SJ
    Mike SJ Supporting Actor
    Nov 10, 2003
    718
    send the driver back and get a replacement
  3. Tom-K
    Nov 29, 2000
    119
    I know its not the driver because I had him connect a 7" inch 8 ohm driver as well, and it does the same thing. Anybody have experience with the crossover. The schematic on Zalytron's website is what I used, but I noticed another website www.wmeckle.com he added another 33uf capacitor into the circuit. Would the missing cap have anything to do with it?
  4. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,737
    474
    9,110
    If somehow the impedance goes really low for the midrange+crossover, it could cause the amp to clip at high enough volume levels.
