Foam surround rot question
Discussion in 'Archived Threads 2001-2004' started by Ben_wood, Sep 5, 2002.
  1. Ben_wood
    Ben_wood Stunt Coordinator
    Jun 21, 2002
    234
    Many vintage speakers suffer from the dreaded foam surround rot problem. I have a pair of JBL L150 towers (early 80s) that I have had to replace the surrounds on the woofers and passive radiators. My question is: Are modern speakers still vulnerable to this problem or have there been advances in manufacturing that has solved this?
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    I'd imagine that eventually they'll all fail at some point and that would be a function of construction, use, environmental conditions, etc. In many cases though, as you've determined, they can be replaced. A specific question might be better directed towards the manufacturer of the driver as perhaps they've access to accelerated aging tests as a prediction of longevity.
  3. Pete Jennings
    Pete Jennings Second Unit
    Sep 13, 1999
    333
    Ben, you can actually replace the foam surrounds if you would like to keep the speakers, check out this link . I researched this problem for a friend a few years ago, and kept the link just in case.
    Good luck!
    Pete
  4. MarkE
    MarkE Auditioning
    Sep 3, 2002
    7
    Just don't go with foam. I have a pair of Dynaco speakers purchased in around 1970. I took them to college in 1973, and used them pretty much continuosly since, and last week, my daughter took them to college with her. They still sound great. Butyl not Foam.
  5. Manny_S
    Manny_S Stunt Coordinator
    Sep 4, 2002
    54
    SImply Speakers does foam surround replacement. Two of my friends have used their service with great results. They also sell kits if you think you can handle the repair yourself.
  6. Ben_wood
    Jun 21, 2002
    234
    When I asked this question I was thinking specifically about the brand new Hsu VTF-2 in my system. It has a foam surround on the driver, but I've read that the VTF-3 has a rubber surround (touted for it's extra life span). I guess that I'll email the good Dr.(thanks for the suggestion Chu Gai!) and ask if they have considered offering an upgraded version of the 10 in. driver (with perhaps a butyl surround like MarkE mentioned). My other speakers - Ascend Acoustics - all feature the rubber surrounds. I just would really like to avoid the foam rot issue if at all possible.
  7. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    let us know what, if anything, you find out. now Ben...i'd say getting 30 years out of your speakers is pretty damned good, rot or no rot!
  8. Ben_wood
    Jun 21, 2002
    234
    According to Dr. Hsu there are currently no plans to upgrade the VTF-2 driver with a rubber surround.
  9. Clinton McClure
    Clinton McClure Casual Enthusiast
    Jun 28, 1999
    4,370
    400
    4,110
    Central Arkansas
    Clint
    Foam rot is the main reason I only buy speakers with a Santoprene surround.
