Foam/Plastic Speaker Port Plugs?!
Discussion in 'Speakers & Subwoofers' started by Mike_Cif, Mar 8, 2005.
  1. Mike_Cif
    Mike_Cif Stunt Coordinator
    Sep 26, 2003
    83
    Hi,
    I have some speakers that I'd like to plug (the ports) to help increase tighter bass. I can't seem to locate where to order some, I have 3" ports on my main speakers and 1" on my surrounds.
    Here is an example of what i'm looking for:
    [​IMG]
    [​IMG]
    thanks guys
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    A rolled up sock works just as well.
    Plugging your ports will also likely result in a slight loss of sensitivity.
  3. Dean_S
    Dean_S Second Unit
    Feb 4, 2004
    261
    I haven't been able to find any of these either, but recently I noticed that some new solid core wood doors we are buying for my office came with a foam plug in the hole for the door knob. Luckily we still had two doors that were not installed yet so the contractor hadn't thrown the (valuable to me) plugs away yet. It's just regular foam that you can buy many places but I have no way to cut foam into perfect circles like you (and I) want them.
  4. Eric Ha
    Eric Ha Stunt Coordinator
    Sep 27, 2004
    146
    Try Nerf brand port plugs. They look like little footballs. [​IMG]
  5. Chris Quinn
    Chris Quinn Screenwriter
    Jan 12, 2003
    1,127
  6. Geoff L
    Geoff L Screenwriter
    Dec 9, 2000
    1,693
    Hi Mike
    As mentioned, socks, kids nerf balls/toys, etc, can be used.
    For a much more pro look, and getting I'm sure s exactly what you want, you might try this place.
    Size, lenght, and even density can be selected.
    Take a look and give them a call if you if you need more information.
    Check'em out ***Here***
    I think they have what you really want..
    Cheers
    Geoff ¥
  7. Mike_Cif
    Sep 26, 2003
    83
    Geoff,
    that store is perfect, thanks exactly what I'm looking for.
    Thank you!!
    [​IMG] :b
