Foam Pad for Center Channel Speaker
Discussion in 'Archived Threads 2001-2004' started by Brian Henchey, Aug 19, 2002.
  1. Brian Henchey
    Aug 23, 2000
    35
    After reading horror stories about "bowing" resulting from placing heavy center channel speakers on top of Mits projection TV's, I mounted my Polk Csi40 above the TV on a Vantage Point PTW20-B angled TV wall mount purchased from Best Buy. Although I am with happy with the placement and the sound, I think I getting some vibration on certain higher dialog frequencies (sibilants at the end of sentences, etc.). Would anyone have a recommendation of a type of foam pad to put between the speaker and the mount?
    Thanks in advance,
    Brian
  2. Clay Autery
    Clay Autery Stunt Coordinator
    Oct 23, 2000
    158
    Sorbothane.com 1/4" or better...
  3. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    mouse pads work great.
