Sathyan
- Jun 17, 2002
My brother just upgraded from an HK receiver to Roksan integrated amp (using Mirage OM10 speakers), thereby losing the FM tuner functions. He doesn't want to use the receiver as a tuner because it has problems. What external tuner would you suggest? It can be digital or analog. Used it OK. Solid-state preferred over tubes. He's going to use it to listen to Chicago's WFMT (classical). Any ideas for an indoor antenna would be appreciated. Budget of $250 for the tuner and antenna combined.
thanks
sathyan
thanks
sathyan
