FM signal booster for receiver
Discussion in 'Playback Devices' started by Gavin_mi, Aug 22, 2005.
  1. Gavin_mi
    Gavin_mi Stunt Coordinator
    Jul 3, 2005
    65
    not sure if im putting this in the right place, but it is for my receiver so here goes. In my house on my cheapie pioneer (514) I get 2 maybe 3 (depends on the day) radio stations (FM) and in my truck sitting right out side I get 9. is there something I can set on a small shelf that I can plug into the back of my receiver to boost the radio signals? If need be I can plug it into an outlet. I have heard of things like this, does anyone use one? can anyone suggest a brand to look at?
    is this the kind of thing im looking for?
    http://www.beachaudio.com/product_in...01-00&ref=true
    thanks for any info,
    Gavin
  2. Dean_S
    Dean_S Second Unit
    Feb 4, 2004
    261
    What are you using for an antenna on the recvr??? Is the house constructed using metal mesh on the walls (like stucco would have)???
  3. Gavin_mi
    Jul 3, 2005
    65
    its a frame house with vinyl siding. Im using the antenna that came with the receiver, it never crosses any other wires, and I have move it all over the place to try and get the best signal.
  4. Gavin_mi
    Jul 3, 2005
    65
    should I move this to a different section to get more replies? surely someone is using one of these.
  5. ChristopherDAC
    ChristopherDAC Producer
    Feb 18, 2004
    3,729
    Do you have a TV antenna in your house? If so use a splitter and a balun if necessary to send the signal to your audio reciever as well as your TV -- since the FM band is buried in the VHF TV band, that high-gain antenna will give you great reception.
  6. Gavin_mi
    Jul 3, 2005
    65
    I dont have one of these, could I just pick one up at walmart? I have digital cable for watching TV.
  7. joseph_harmon
    joseph_harmon Auditioning
    Aug 22, 2005
    5
    What kind of antenna do you have?
  8. Gavin_mi
    Jul 3, 2005
    65
    it is just the clear sheilded wire (looks to be copper), that is about 3-4 foot long that plugs into the back where is says to....
  9. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    Does your receiver have spring clips or a coax connection for the attenna? Radio Shack has some small FM attennas that would probably work better than a bare wire, but they use a coax connection.
  10. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i bet that's your problem right there ... you're using a crappy antenna.
    just go buy an external fm antenna. it doesn't even have to be a fancy powered one. since it sounds like you get good reception from outside the house, i think a basic antenna inside will work.
    try this url: http://www.terk.com/pdfs/AMFM-LB.pdf
  11. Gavin_mi
    Jul 3, 2005
    65
    thanks alot guys, ill hit radio shack or walmart tonight and get a coax antenna tonight.
    Gavin
  12. David Blair
    David Blair Stunt Coordinator
    Jan 31, 2004
    70
    I'm in the same situation but my house is stucco. Would I need anything else besides an external FM antenna?
  13. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    doubtful stucco would make a difference david. if you get good reception outside, you'll get good reception inside regardless of your house. if your *area* gets bad reception ... then you'll be in a tougher spot.
  14. David Blair
    Jan 31, 2004
    70
    Thanks for the quick reply!
  15. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    np david ... good luck.
