David Masefield
- Jul 25, 2003
Not the variety with wings that you see when you've had one too many Bourbons.
My room has a problem re doors.
There are big sliding doors either side of my home theatre where the surrounds would/should go. I would prefer not to use stands to position the side speakers and so I was wondering whether anyone had had experience with or had actually suspended speakers before. I know they do that sort of thing with rock concerts etc with the front of house speakers etc but was wondering if anyone had done this with their home setup. Hung speakers on chains or steel cables above doorways, walkways, kitchen bench etc and angled them to suit the seating?
Another thing I was wondering was.....
5.1, 6.1,7.1 etc use two surround speakers and varying numbers of rears from none to two.
What would stop you from using more than one set of surround(side) speakers to play you surround sounds.
What would be required to do it if you can?
