Flush mounting Focals
Discussion in 'Archived Threads 2001-2004' started by Ron D Core, Apr 18, 2002.
  1. Ron D Core
    Ron D Core Stunt Coordinator
    Mar 31, 2002
    158
    Does anyone know of a good way to flush mount the Focal drivers with the semi square/circular mount? Making the shape wouldn't be too much of a problem, but the driver needs to sit in a circular whole, and the flanges have to sort overlap too much. Is my only option to make a .125 or .25" cover to go over the baffle to bring it up flush with the driver?
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    You must handmake a custom template, then use a template adapter to cut the recess for the mounting flange. The driver hole can be cut with any circle cutting attachment
  3. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    Thomas is correct. Make a template by hand, and if you make a mistake, start over -its not as serious as messing up a driver opening trying to route it freehand. I use two pieces of 1/4" Masonite glued together for template material.
  4. Ron D Core
    Mar 31, 2002
    158
    So when you say template, your talking about a guide for the bit bearing to run along? I've little experience with this stuff. I've been cutting all my holes with a jigsaw for the past 5 years.
  5. ThomasW
    Nov 6, 1999
    2,282
