Jassen M. West
- Jun 22, 2000
When using a router to create the c'bore to mount the driver do you take into account the thickness of the veneer? Also how do you cut the circle into the veneer for the driver to fit through? When should veneering be done before the c'bore for the flush mount or after?
thanks,
jay
thanks,
jay
