"Fluffing" an auto-on Subwoofer
Discussion in 'Speakers' started by Matt*B, Jun 23, 2004.
  1. Matt*B
    Matt*B Stunt Coordinator
    Apr 19, 2004
    94
    Hey all,
    I have a nice Cerwin Vega Subwoofer, and I really enjoy it - however I have one question about it. The power option on the sub are "off" and "auto on".
    Since it is auto on, when it's turned on, the sub will nto kick in until there is a significant enough bass signal. Sometimes if the volume is low, or if the bass signal isnt strong enough, the sub won't kick on when it should.... there may be a 30 second delay.
    I wanted to know if there was anything I could do to fluff the sub into active mode manually so that it will immediately pick up any bass
    M
    ([email protected])
  2. Matt*B
    Apr 19, 2004
    94
    Hey all,
    M
    ([email protected])
  3. aaron campbell
    aaron campbell Second Unit
    Jan 11, 2000
    281
    Hey Matt, Are you using the lfe input to the sub? If so, you should be able to boost the signal on your receiver settings.
    Aaron
  4. aaron campbell
    Jan 11, 2000
    281
    Aaron
  5. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    Does your sub have left and right RCA inputs? If so, go to radio shack and buy a splitter so you can input the signal to both inputs.
  6. SethH
    Dec 17, 2003
    2,867
  7. Matt*B
    Apr 19, 2004
    94
    Hey guys....
    If by "lfe" you mean the RCA input, then yes, that's what I am using....Yea, I have the L and R inputs filled already as well. Boosting the amp sub volume and lowering the phsical sub volume makes sense and I'll give that a shot...
    Matt
  8. Matt*B
    Apr 19, 2004
    94
    Hey guys....
    Matt
  9. jeff peterson
    jeff peterson Supporting Actor
    Nov 29, 1998
    675
    or you can just leave it always on..doesn't draw much current...that's what some of us here, do. In fact, the SVS guys recommended it to me when I had the same question a couple of years back
  10. jeff peterson
    Nov 29, 1998
    675
  11. Matt*B
    Apr 19, 2004
    94
    Hello...
    I thought about leaving it on. But i thought the sub would just go into dormant mode again when the sound was shut off. That is, once there is no sound for a bit, it will go back into sleep mode.... Or does leaving it on somehow keep it more ready for sound? I just want it to BE ON ALWAYS and be ready to punch as soon as the first bass line hits....
    Matt
  12. Matt*B
    Apr 19, 2004
    94
    Hello...
    Matt
  13. ScottCHI
    ScottCHI Screenwriter
    Feb 21, 2004
    1,292
    well, do you have the option to have it "always on" or not? if you do, then leaving it "always on" is the best option, barring some reason this not be feasible. "always on" is just that; always on. no "sleeping".
  14. ScottCHI
    Feb 21, 2004
    1,292
  15. Andy Goldstein
    Andy Goldstein Stunt Coordinator
    May 6, 2003
    214
    interesting use of the term "fluffing". and yes, i understand what it means [​IMG]
    ag.
  16. Andy Goldstein
    May 6, 2003
    214
    ag.
  17. ScottCHI
    Feb 21, 2004
    1,292
    heh
    [​IMG]
  18. ScottCHI
    Feb 21, 2004
    1,292
    heh
    [​IMG]
  19. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    As was mentioned, turn the gain up in the receiver's sub level setting, and adjust it down on the sub to get your correct level. The higher output voltage from the receiver should turn it on correctly.
    Your receiver's bass management settings are a factor as well. What crossover setting are you using? What are your speaker settings? Large or small? Is your sub set to LFE only?
  20. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
