Floating Floor
Discussion in 'Home Theater Projects' started by Raymond, Jan 15, 2006.
  1. Raymond
    Raymond Auditioning
    Jan 3, 2006
    6
    I want to install a really nice home theater... What is the best way to float the floor and install the walls?
  2. MikeGee
    MikeGee Second Unit
    Dec 11, 2004
    292
    Floating floors are not hard to install, they each fit into one another. Just measure and cut. Not sure what you mean by the best way to install the walls.. do you mean soundproofing?
  3. Raymond
    Raymond Auditioning
    Jan 3, 2006
    6
    Thanks for your response... Yes I'm talking about sound proofing?
  4. Raymond
    Raymond Auditioning
    Jan 3, 2006
    6
    Yes... sound proofing...
  5. chris_everett
    chris_everett Second Unit
    Jul 20, 2003
    403
    Check out www.soundproofing.org. It's an ugly site, but it has lots of information on how to build a soundproof space. You should be able to attach your walls onto your floating floor normally. http://www.auralex.com/ has a product that you can use to float the floors with.
  6. Raymond
    Raymond Auditioning
    Jan 3, 2006
    6
    Thanks Chris... you have been very helpful and expedient...
  7. joseph westcott
    joseph westcott Second Unit
    Oct 24, 2005
    355
    It is a LOT of work but is well worth it, IMO.
    I laid one inch strips on 6inch centers and filled the gas with insulation panels. Laid the plywood over that, quickstep membrane, maple flooring, done.
    Just make sure you do not attach anything to the floor that will undo all your hard work. Here is a link that I think will get you started.
    http://www.diynetwork.com/diy/hi_fam...465241,00.html
    Pictures of the floor can be found below.
  8. Raymond
    Raymond Auditioning
    Jan 3, 2006
    6
    Great pictures... Love the room...
    Thanks for sharing...
