DO NOT use a wood cutting blade on your miter saw to cut metal. You need a metal cutting blade. Just pick up a hack saw from Home Depot.
Bill
Thread a nut on just past the cut and hack saw 2/3 thru then snap the end off. Clean up with a file or grinder and remove the nut. The nut will correct minor thread problems as it is removed.
