Flexy almost done...rubber washer and PE Vinyl questions
Discussion in 'Home Theater Projects' started by Joe Hsu, Aug 25, 2003.
  1. Joe Hsu
    Joe Hsu Supporting Actor
    Jul 2, 2001
    812
    So I have all the pieces cut and drilled, and soon to be sanded with a palm sanded that someone lent me (whew!)...and all that's left are the rubber washers and the finish. Where does one go to find these rubber washers, and specifically, around Detroit? Home Depot doesn't have them, neither did a hardware store around teh corner.
    As for the PE vinyl, I was wondering if I HAD to have the cut edges of the MDF sanded down, or could the vinyl's adhesive side stick to the rough wood still. If it will still stick w/o any future worries, that'll save me a crapload of sanding...
    All of my DIY projects are almost complete! Should be done by the end of the week, depending on PE shipping and laziness. [​IMG]
  2. Dave Nibeck
    Dave Nibeck Stunt Coordinator
    Feb 23, 2000
    152
    I did not use rubber washers. No problems.
  3. Bob Kavanaugh
    Bob Kavanaugh Second Unit
    Jan 17, 2003
    282
    It seems to me that if you use rubber washers, it would decrease the lateral stiffness of your stand, causing it to have a bit of sway.
  4. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    i used the zinc washers at HD and really cranked on it with my 15/16ths wrench that i bought for my flexy, it is rock solid and will support anything. I actually just finished it up (painted it) and put it back together, i will post some pics when i get some time, i also picked up the 5/8ths rubber feet at HD, now i am not worried if its on hardwood.
  5. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
  6. Arthur_King
    Arthur_King Stunt Coordinator
    Jun 14, 2002
    62
    My understanding is that the reason for the rubber washers is to keep the wood/marble/mdf/granite/etc from being scratched by the metal washer/hexnut.
    If thats not a concern (say you're never going to use that MDF/Granite/Marble/Plexiglass for anything else) then its true that youd get less "flex" from just metal washers.
    Daffy Arthur King
  7. Bob Kavanaugh
    Jan 17, 2003
    282
    I thought the rubber washers were for some sort of "vibration reduction". At any rate, I don't think they are necessary, but the rubber feet from Home Depot that Allen mentioned are worth their weight in gold. I have them on my stand too.
  8. Joe Hsu
    Jul 2, 2001
    812
    hmmm, okay, I was under the impression that they were used for vibration reduction purposes as well, but if it's really for other reasons, I'm not too concerned if the wood gets scratches or impressions...so then it's just up to the PE vinyl to come in, I guess.
    As for the rubber feet, maybe I'll pick up a set in the future, but I'm just sitting the rack on carpet, so the bare threaded rod should be fine for me...
    I can't wait. I should finish up my stands today or tomorrow, and then the rack later on this week...the sub's bumpin along as I type...all is good. [​IMG]
  9. Joe Hsu
    Jul 2, 2001
    812
    Well, shipping at PE is rather insane, so I just bought 2 rolls of the cherry vinyl instead of paying another 6 bucks in the future...so I'll be finishing my rack in cherry, along with the wood-parts of my stands.
    Is PE's shipping generally pretty fast? It says they're in OH, and I'm in MI, so UPS shouldn't take more than a day or two...meaning Thursday or Friday, which would be awesome.
  10. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Joe,
    I get parts from PE in 2 days most of the time. Before I had my dealer account it was 3 days. So I'd expect you to have your shipment in 2 days probably.
