MikeyWeitz
- Feb 10, 2002
I will be wall mounting my new JBL E10's for surrounds.
I live in an apt, so I am limited to using my white, flat speaker cable. Obviously, I am going to have to run the wire up the walls.
I am wondering what you might sugest I use to secure the wire to the wall so it does not flop around.
Basically, white painted walls. I was figuring to use some double sided tape on some sections of the wire (not on all of the wire, maybe spaced out a foot or so.
ANy suggestions? I do not want to use the wire tracks as I would need quite a bit and it would get $$$.
Double sided tape the way to go? If so, any specific type?
If not, what do you recommend?
Thanks.
Thanks.
