Flat Speaker Wire (1 Viewer)
Sanjivnpatel
Hi;
I am planning to use 14 gauge flat speaker wire for connection. This wire is paintable. I have two questions.
1.If I stick this wire on the wall and paint it, how visible this would be. Should cut a whole in the wall and pull it to make it completely invisible or pain will make it fairly invisible?
2.If I cut the whole in the wall and pull the wire, is there a detailed process describe somewhere? I am not sure how to pull the wire in the wall.
Thanks.
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
First, welcome to the Forum!
2. If I cut the whole in the wall and pull the wire, is there a detailed process describe somewhere? I am not sure how to pull the wire in the wall.
If you’re talking about dropping the wire between a wall-mounted speaker and the baseboard, try the directions at this link.
Wayne A. Pflughaupt
Mindy
