Flat RCA cables do they exist?
Discussion in 'Speakers & Subwoofers' started by Travis R., Mar 4, 2004.
  1. Travis R.
    Travis R. Agent
    Dec 23, 2003
    39
    I was wondering if there is such a thing as flat RCA cables that you can paint because my friend is unable to hide his cables for his subwoofer and wants to make them as inconspicuous as possible.
    Any suggestions would be appreciated.
    Cheers.
    Travis R.
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,265
    72
    9,110
    Corpus Christi, TX
    Wayne
    Can't say as I've ever seen any.
    What's his situation? Perhaps someone can recommend something. Like, if the room is carpeted he could simply tuck the cable between the carpet and baseboard.
  3. ChrisBee
    ChrisBee Stunt Coordinator
    Mar 4, 2004
    195
    Aren't most Nordost cables flat? Their famous "Flatline Gold" speaker cable is flat. Their Blue Heaven & Red dawn interconnects are expensive but are flat. They do a 3 metre Bassline flat subwoofer cable I believe.
    I've seen various flat cables on reels and they can be made up into any desired plug/length/configuration by the dealer.
    A visit to a well stocked AV/hifi or car-audio shop with plenty of cables on reels should unearth some cheaper (flat) alternatives.
    Chris Bee
  4. Travis R.
    Travis R. Agent
    Dec 23, 2003
    39
    Thanks for your help I will look into it.
    Travis R.
