Flashing picture (1 Viewer)
bug_n_67
Maybe someone can help, Ive just bought a Pioneer 9120 and hooked up my blu-ray and I seem to be having a picture problem. When the blu-ray is playing the picture on the screen flashes on and off, seems to be every few sec it plays then goes to a blue screen and then plays and so on. So any ideas, bad cables or something else. It's just a simple hook up one HDMI from the blu-ray to the 9120 and then one from the 9120 to the tv. Thanks for any input.
JohnRice
Bounded In a Nutshell
A Mile High
Sounds like a handshaking issue. Make sure the cables are fully plugged in, and try swapping them. If that doesn't fix it, you may have bad cables or a problem with the receiver.
maanw2357
