Flashing "Peak" Light
Discussion in 'Archived Threads 2001-2004' started by CaseyLS, Jan 28, 2003.
  1. CaseyLS
    CaseyLS Second Unit
    Oct 3, 2002
    370
    I was playing music through my computer to my Marantz 4200 and I noticed a flashing red light on my reciever. Right next to it, it says "Peak." Is this bad and if it is is there anything I can do
  2. Armand G
    Armand G Stunt Coordinator
    Oct 18, 2000
    151
    This only happens with analog connections. In the digital domain the receiver arranges the input level automatically.
    You should be careful that the peak indicator doesn't flashes all the time because some damage to the electronics can be the result.
    Simply lower the input level on your receiver until the indicator doesn't lite up anymore.
  3. CaseyLS
    CaseyLS Second Unit
    Oct 3, 2002
    370
    So basically turn down the volume on my computer and raise it on my reciever?
  4. Armand G
    Oct 18, 2000
    151
    You can experiment on that. The most important thing is to try in keeping the output level on your computer as constant as possible. Otherwise you have to adapt this level or the input level on your receiver all the time.
    There ought to be an inputlevel on your receiver which you can lower or raise. See your manual.
    I presume you have analog connections from your computer to your receiver?
  5. CaseyLS
    CaseyLS Second Unit
    Oct 3, 2002
    370
    Yes it is analogue
  6. Rob Bruce
    Rob Bruce Agent
    Jan 20, 2002
    44
    I noticed that to just today when I plugged my amp into my pc. I don't think that pc sound cards can generate a high enough level cleanly, and are peaking at high volumes.
  7. Armand G
    Oct 18, 2000
    151
    Good luck!:wink:
  8. Steve_Ma
    Steve_Ma Second Unit
    May 7, 2001
    420
    Check out your manual and look for the section that talks about an "ATT" or "A/D" button. I'm lazy and need to put my 2 year old to bed or I'd look for you. But I'm pretty sure it will automatically attenuate the signal when you are using an Analog source so as not do do any damage, but still allow you to use the Analog source. Something like that.
    Good Luck,
    --Steve
  9. ChrisDixon
    ChrisDixon Second Unit
    Nov 20, 2001
    306
    The ATT will attenuate the signal, but the sound quality suffers. Think about what is happening: you are sending an analog signal, which is being converted to digital, adding attenuation, then back to analog again to go out to your speakers. The much better way to go from an analog source is to put your receiver in Source Direct mode. This is a "pass-through" that avoids all that digital conversion. Not only do you completely eliminate the "peak" light, but you also get much better sound quality, since your receiver is effectivly acting as a pure amp with no degrading processing.
    Chris
  10. CaseyLS
    CaseyLS Second Unit
    Oct 3, 2002
    370
    But I think when I go to source direct I lose my sub.
  11. ChrisDixon
    Nov 20, 2001
    306
    It depends on how you hook up your sub. I had the same decision with my previous receiver (SR7000) and once I heard the performance using Source Direct, I couldn't turn back. I connected mine via left/right pre-outs and set the sub's cross-over to 50Hz to fill out the lower end that my mains couldn't reach. There are other ways too, which you can read about if you do a search on this forum.
    Chris
