Rick Thomas
- Feb 27, 2002
I'm going to be putting a 4" port in my sono sub.What should I use for the port and where do i get something flared for the ends thanks.
Do i need the port flared on both ends or just the end inside the sono?thanks
In order for "flared ports" to have appreciable effect, they should be at both ends and should be large flares such as those seen on the aeroports. You can achieve a flare of sorts with a roundover, but to replicate the kind of flare I'm speaking of would require a monster bit and probably an endcap 5" thick.
The hard answer is to have as large a port as possible (length being the usual limiting factor) and ad some flare.
I suppose it is a bit of a "brute-force" solution, but it seems the right one. I think that particular wheel has been reinvented a few times. Even very large ports,though, exhibit signs of compression at surprizingly low levels (See Dickason, LDC 5th Ed, also this article ). And they are of limited utility with modern drivers which have very small box requirments, yet can move prodigious amopunts of air. This is one reason I've become interested in passive radiators of late, they bypass these problems.
You may get rid of the port noise, but you add mass to the system (diaphragms and "added mass" to tune the PR's) that need to be controlled. So you have one driver motor controlling the mass of 2 or three cones! Outside the harmonic resonance of the PR's, the motor is fighting the extra mass at the same time it is trying to control it's own enertia. I do not know all the facts, but I think that there are a few challenges even with PR's.
As you have said before "There's no free lunch", or something similar!
Keep up the good work.
Could this be why PR subs are said to have poorer transient response than their ported counterparts?
Brian
An "ideal" PR would probably be one that has a very very soft suspension, SQ wise that is.
Yep, that's when they act closest to an "ideal" reflex system. That's why I like the Lambdas, and part of why they used to be considered the pre-eminent PR's.
In a ported system the air is compressed and pushed out the port, the driver must "suck" the air back through the port to return to it's starting position (There is some residual "spring" pressure within the box to help). In a PR system the air compresses and moves the PR's out (displacing air outside the box). The PR's provide some help in recovery, as they want to return to the starting position too.
This is not what happens, but I think the misconceptions are common. The driver does not "push air out the port", nor does it directly displace the PR's, or push them out and suck them back in. In a reflex system, the port/PR resonate so much at Fb that the pressure they create damps the motion of the driver. That article illustrates it nicely.
In addition, the heavier the Mms of the PR the better it sounds, in general, since the free air resonance is pushed further down in frequency, thereby pushing the PR notch/group delay further out of the passband.
Yes.. only at the resonance frequency and you only have that (by itself) if you are playing a sine wave of that freq. Generaly the driver is always moving, creating waves of air pressure/sound pressure.
I admitt that I'm in over my head when discussing this stuff, I've got some reading to do. Thanks for the link and I'm sure I'll be back to pick your brain some more!
I'm familar with reflex theory, my point was that the actual process was the opposite of what you describe. The driver isn't pushing in as the PR's move out..that would be out-of-phase. At the PR's greatest resonance, thay actually move more or less in tandem, and that very pressure almost stops the woofer.
Please read that article.
Also, a large volume of air pushed through a relatively small opening may generate turbulence, or a chuffing sound. Ports can be shaped (flared at the openings) to limit turbulence, however, so the compromise doesn’t have to arise, but must be dealt with. Passive radiators don’t suffer from that problem at all but, unlike ports, they do have excursion limitations.
Maybe we are misunderstanding each other. From your linked paper and using the animated GIF's(?) as a basis, this is how I understand how the system works:
Case 1- Above the port/PR's resonance, little or no air moves thru the port/moves the PR. The active driver moves as needed.
Case 2- At the port/PR resonance, LOTS of air moves thru the port/moves the PR. And the active driver moves very little as the internal pressure waves work against the drivers movement. (The driver is exciting the system without moving... cool stuff!)
Case 3- Below the port/PR resonance, lots of air moves thru the port/moves the PR, but it is out of phase and cancels the active drivers output (acting like an open box). The driver is unsupported and can bottom out.
Since ALL energy is being introduced into the system only by the active driver, at port/PR resonance the driver is moving the air through the port or moving the PR (and associated air). In or out of phase does not matter to make my point. On a ported system the active driver must push, and pull, the air through the port. In a PR system, the suspension helps to restore the PR diaphragm to the zero point. That may be why you find the PR system sounds better. I still feel that the enertia of the PR/mass and the air the PR moves degrades the sound quality, makes the system "sloppy". Thats an unfair word to use as I have only listened to one PR system and I can say that it did not sound sloppy! The answer is to use closed systems and live with the resulting box size to achieve the output... not a popular idea around my house. I need to study PR's some more and listen to a few more to really see what they can do.
Like I've said, I've got a lot to learn, thanks for the help.
