Flare both ends of a port for Sonosub?
Discussion in 'Archived Threads 2001-2004' started by Scott M, Mar 19, 2001.
  1. Scott M
    Scott M Agent
    Jan 3, 2000
    27
    I'm building a sonosub based on the Shiva and I'm wondering if I should I flare both ends of the ports? Or is 1 end good enough?
    -scott
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,727
    468
    If possible, flare both of the ends. Add 1" to the overall required port length for the total end-to-end length of the flared port. For example, if you needed 20" for a straight port, you'd need 21" for a flared port from end-to-end.
    PatCave ; HT Pix ; Gear ; Sunosub I + III ; DVDs ; LDs
  3. Scott M
    Scott M Agent
    Jan 3, 2000
    27
    Thanks guys. I'm going to have 2-4" ports so I guess I'll need 4 flares. I'm also assuming you would add 1" to each port. I'm getting the ports from partsexpress(do you think these are decent quality?) but I didn't like their selection of terminal cups. I want two sets of posts because my current sub is DVC and I like running them seperately. Any recommendations on where to get a nice heavy duty terminal cup(I'm going to run 10ga)?
    -scott
  4. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
