Adam_Garris
- May 28, 2002
I read that you can fix the oversqueeze in the service menu by upping the asp parameters. However, I got to the max number and the oversqueeze was still present. So I decided to go to the DVD menu and change the tv to 16:9. Then I turned on the 16:9 enhanced mode. It worked, no overqueeze. Is this an acceptable way to fix the oversqueeze? And will it work on all DVDs or did I get lucky?
Thanks for any help,
Adam
Adam
