Fixing DVD scratches
Discussion in 'Archived Threads 2001-2004' started by Anh Pham, Dec 8, 2002.
  1. Anh Pham
    Anh Pham Auditioning
    Jul 28, 2002
    6
    What is the best way to fix a scratched PS2 DVD videogame? Does anyone know of any competent DVD repair kits I should buy? The scratches are all hairline size and after six months of perfect play it is finally beginning to occasionally freeze. None of my other PS2 games freeze so I know its not a hardware problem.
    Thanks for your help.
  2. Ole
    Ole Stunt Coordinator
    Nov 4, 2002
    50
    I generally get my DVD's from Netflix, and it seems half of them freeze right at the best part. I have started polishing each one before I use it. It has really helped. I use a plastic visor polish called ILC Haze away, check your local automotive supply or motorcycle dealer. I did put a Disk Dr. on my Christmas list.
  3. Ken Smith
    Ken Smith Stunt Coordinator
    May 20, 2001
    100
    I used the Disc Doctor on a couple of bad dvd's. Took out the scratches, and they play great. This is not meant to repair deep gouges, only small scratches.
  4. Lando P
    Lando P Agent
    Apr 15, 2002
    40
    I use ScratchOut on my dvd's and cd's. It does a good job. Others use plastic scratch removers from Novus and Meguiar's. I heard they do a better job than ScratchOut but costs more.
