Fixing a Sony reciever
Discussion in 'Archived Threads 2001-2004' started by Aaron_Morris, Jul 29, 2002.
  1. Aaron_Morris
    Aaron_Morris Stunt Coordinator
    Jul 1, 2002
    106
    Dunno if this is exactly the right place to post this, but if not I appologize, and please move it to where it belongs... Now, I have a Sony stereo reciever sitting here that I got from a guy inlue of cash. Now it seems like a decent little thing, maybe good for running in a bedroom or for a sub or something... Anyway, it has a problem (or maybe a collection of them). It has a bad distortion sound that comes up more often than not, and can be alliveated by fiddling with the RCAs on the back, or afirm thumping. Does anyone here tinker with this stuff? What might I look at doing to it? Does anyone fix stuff with any regularity that might want to take a shot at it for fairly cheap? If anyone is interested I can give more details as to what it does.
    Thanks in advance
  2. Jeff Rosz
    Jeff Rosz Second Unit
    Sep 24, 2000
    335
    hiya,
    from what you describe, it sounds like the simplest problem it could be is an oxidation build-up inside the rca connectors. for starters you could try an oxidation removal spray applied to a pipe cleaner. if that doesnt work, you could check the solder connections inside. all it might take is just re-melting the solder on the connectors.
  3. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    that sounds like a pretty reasonable suggestion Jeff. If the RCA's look like they're beyond hope, they could also easily be replaced by an individual. taking it to the shop is probably not going to be very cost effective for you.
  4. Aaron_Morris
    Jul 1, 2002
    106
    To try and clean them, what would I use, somthing like this: ?PE cleaner
  5. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    That would be good to have on hand in any event. Also consider this little offer at Caig's site. It's a little assortment of their products in small tubes. When getting into tight spaces, pipe cleaners, or those foam swabs that you can get from the Shack are pretty good. If you open the unit don't have it powered and make sure its been powered off for some time before you start touching thing. Good luck.
  6. Lee Conner
    Lee Conner Auditioning
    Aug 1, 2000
    5
    Aaron -
    Parts express just became my new favorite place to shop! Thanks for the heads up.[​IMG]
