Fixed a problem I didn't know I had (1 Viewer)
Randy Tennison
Randy
For a long time (several years), I wasn't happy with the sound from my system. I thought my Energy Take 5's, along with my Yamaha 995 should have sounded a lot better than they did.
Then, I discover something about my Toshiba DVD player. I was bored, waiting for my wife to come back from a potty break while watching a movie, and started flipping through the DVD player menu. I discovered that it had a feature called "Dynamic Range Control", and it was defaulted on. I turned it off, and WOW, what a difference.
That's what my system was supposed to sound like. Now, I need to re-calibrate my speakers, because the sound is out of balance. But man, it sounds much better.
Only took me a couple years to discover it!
Vince Maskeeper
Usually DRC on the player only affects the analog outputs- not the digital ones. Also, DRC USUALLY only works on DD sources, and even then it only applies on titles that have DRC flagging. Interesting.
-V
Kenneth Harden
I always make a habit of checking the munu's on everything to make sure they are set to my liking.
The Pioneer receiver we have was defaulted to a 'mild' compression. It makes a huge difference turning it off, as the speakers (JBL HLS series) are more than willing to take some thrashing (well, dynamic peaks with ease)
maltby
