Fitting a bigger television
Discussion in 'Archived Threads 2001-2004' started by john webb, Aug 14, 2002.
  1. john webb
    john webb Auditioning
    Jan 14, 2002
    7
    I have a question about the 36udx10s width which it says is 34 13/16th
    I just bought the 32udx and I still have a lot of room around it in my entertainment center which I measured at 34 5/8th width. my question is, is the measurement on the 36 dead on? I want to take the 32 back and try the 36 but it's alot of trouble if it doesn't fit.
  2. Steve_Tk
    Steve_Tk Cinematographer
    Apr 30, 2002
    2,833
    If the mesurements are from the manufacturer then it's probably dead on. But I usually over compensate for measurements when dealing with TV sizes just to be safe.
  3. John-Miles
    John-Miles Screenwriter
    Nov 29, 2001
    1,216
    3
    110
    well it would only be off the fit by 1/4 inch you could get an electric sander or a hand plane and modify your entertainment center quite easily.
    but then it wont look pretty on the inside, but unless your tv is see through it wont matter.
