gene c
The Take Classic speakers are wall-mountable. Look at the back of the speaker and you will see the bracket on the top. They also have the standard 1/4" screw inset for using after-market brackets (I dounloaded their manual to be sure). The htib systems from Sony, Samsung, LG, etc are usually not recommended for their lack of inputs, poor sound quality due to low quality speakers and subwoofer and if one part breaks you usually have to replace the whole thing. The Onkyo receiver/speaker packages are much better but the speakers are still where they cut costs. The Energy TakeClassic/Lava sub combo would be much better than anything from onkyo until you step up to the HT-S9400 http://www.accessories4less.com/make-a-store/item/ONKHTS9400/Onkyo-HT-S9400-THX-7.1-Ch-Network-Home-Theater-Receiver/Speaker/1.html But if money truely is tight then consider an Onkyo factory refurbished system from ac4l.com http://www.accessories4less.com/make-a-store/category/HTIB/Home-Audio/Packaged-Systems/1.html They come with a one year factory warranty. The Pioneer comes with the entry level version of MCACC automatic setup and room correction program. It doesn't help you place the speakers but sets their volumes, distances sizes and evaluates the room acoustics and adjusts the 5 band equilizer for the best sound.
