First Sub Project -Any advice please? (1 Viewer)
paullee
Hi, I live in the UK and am just about to embark on building my first sub. I plan to do it in stages, keeping it simple initially and then adding stuff as I go along. My initial thoughts are:
Possibly an Audax 10 or 12" Driver (PR240Z0 or HT300DM)as we're a bit limited for decent drivers under £100 over here and anything coming from the US costs a fortune in postage!
A sealed enclosure of 60L made of 30mm MDF with 4mm Aluminium backplate.
Initially using it for HT from the Subwoofer output of a Marantz SR4200 Receiver so just gonna start with a Linkwitz-Riley Transform circuit tuned to 20HZ into a salvaged 100W BK Electronics Amp, will then add crossover later.
Couple of questions:
1. If I'm downward firing it will I need totally adjustable phase control or will the 0 or 180 switch on the transform circuit suffice?
2. If not, any suggestions of how to incorporate one?
3. Best software tool to use?
Last but not least, if I then want to use it for Music what things should I be thinking about and what would be the best way to connect it up?
Thanks in advance.
Paul
Total Newbie.
KurtJ
Paul,
For any sub design I'd recommend a variable phase control because it will allow better blending of the sub with the rest of the system.
Surf the web for software. Adire has LspCad.
vasyear
